lots of vehicles have no markings on the plateNope not grey at all.
No GTW no towing.
The capability of the towing vehicle
The chassis plate on the vehicle (see table in Section 7) states the maximum weights allowed - the Gross Vehicle Weight (GVW) and the Gross Combination Weight (GCW).
The vehicle handbook will either repeat what is on the chassis plate, or for convenience, might directly specify the maximum weight of trailer (eg 750kg) which is allowed to be towed. The V5C registration certificate often shows this too, under sections O1 and O2 (depending on whether trailer has brakes or not). Exceeding any of the above weights is likely to be construed as using a vehicle in a dangerous condition.
Where the sum of the maximum plated weights of the towing vehicle and of the trailer added together exceed the plated GCW of the towing vehicle, this is not a problem as long as the ‘actual’ weights of the vehicle and trailer (which may not be fully laden at the time) do not exceed the plated GCW.
Maximum authorised mass
Maximum authorised mass (MAM) means the weight of a vehicle or trailer including the maximum load that can be carried safely when it’s being used on the road.
This is also known as gross vehicle weight (GVW) or permissible maximum weight.
It will be listed in the owner’s manual and is normally shown on a plate or sticker fitted to the vehicle.
The plate or sticker may also show a gross train weight (GTW), also sometimes called gross combination weight (GCW). This is the total weight of the tractor unit plus trailer plus load.
The gov site is a loosely worded guide re the actual law.
A quick read of the licence guides indicates that that for him to use the full weight he would require c+e
Even c1+e isnt enough
And for over 3500kg trailer close coupled brakes however i cant find anywhere that stipulates whether only air is acceptable or whether vacuum or hydraulic will suffice
Or electric as i believe there are some electric brakes now approved for uk use but i dont know what weight limits they havr
I had a quick look into this for my Hilux Surf, a Japanese import. There's no GTW information on the VIN plate, and even after numerous emails back and forth to Toyota UK and Japan, they were unable to give any weights. From what I understand, that puts towing into quite a grey area, and I've since removed the towbar anyway.
Interested to see what you find out!
Hey it's not a grey area. Having read the construction+use regs, spoken to gov bodies and also having got email replies from the senior advisory police officers....
Assuming your Surf is pre-1997 (things changed in 1997) if there is no safety plate, you can tow what you want so long as it's safe. Safe means it has to be within manufacturers specs, if there are any, and, erh, safe. The advantage you have is that it's more difficult for the police to prosecute if you don't have a safety plate.
If you read construction+use regs you will see that imported vehicles have some exemptions. Among these is the exemption to have a safety plate.
The safety plate also has axle limits and car weight limits. So saying "no GTW, no tow" would also mean "no axle limits, no passengers". In the same way classic cars have no safety plates, but can still tow. And home made trailer have no safety plate but can still carry a load (from 1997 all trailers must have safety plates, but of course no requirement to prove the age of a trailer so meaningless law for amateur built trailers).
BUT things changed for vehicles built 1997 onwards (EU homogolisation I think) and I'm sure the changes affected towing but I'm not sure what the rules are after 1997.
If you are unsure the Police have a help desk for such things.
I have rang .gov and enquired as to the legality of this, they told me they could not answer over the phone so have emailed .gov regarding this question .
and will post their reply
well as expected... no reply from the helpline !!
 he explained to me that not many people/ police and even the ministry guys are fully up on all these legalities there are too many grey areas, for eg  if no plates on trailers the tyre loading limit was used etc etcsnap!!However if no weight was displayed then tyre load index's would be used.
I have had a reply to my e-mail to the Department for Transport, which (in my opinon) finally clarifies the situation.
The reply is as follows:
"Thank you for your email of 16 June to this Department about the fact sheets published on the Department's website providing guidance about towing. Your email has been passed to this section because we are responsible for the regulations relating to towing.
There are two different circumstances which dictate the permissible maximum weight of towed trailers:
1) The towing vehicle manufacturer specifies the maximum mass of a trailer to towed: or,
2) The towing vehicle manufacturer specifies a maximum trail weight of the combination: i.e. maximum mass of towing vehicle and trailer.
The first is quite clear and is self explanatory. The second permits some flexibility and therefore if the towing vehicle is not fully loaded and is below the maximum vehicle weight, when a trailer/caravan is attached to the vehicle there may be some remaining weight capacity within the overall maximum combination (train) weight. However, the driver of the vehicle is responsible for ensuring that the nose weight of the tow ball, the weight limit of the tow bar/ tow bar mountings or any of the axle/gross/train weights are not exceeded.
In the example given on the fact sheet "Towing cars and light vehicles: frequently asked questions" we have assumed, for simplicity, that the towing vehicle is fully loaded to its maximum capacity and this is indicated by the sentence "So if for example you have a car with a maximum weight of 2180kg and a train weight of 3980kg the maximum towing capacity will be 3980kg minus 2180kg which gives a towing capacity of 1800kg", which you quoted in your email.
The Road Vehicles (Construction and Use) Regulations 1986 don't explicitly state that to calculate the towing weight you subtract the maximum vehicle weight from the maximum train weight. However, we have aimed to summarise the regulations in a simple format for the general public.
We are unable to comment on any actions taken by enforcement officers, including the police.
As you will appreciate the above views are my opinion and not those of the Department as interpretation of the law is the prerogative of the courts.
I hope this clarifies the situation."
The sentence: 'The Road Vehicles (Construction and Use) Regulations 1986 don't explicitly state that to calculate the towing weight you subtract the maximum vehicle weight from the maximum train weight' is the important one.
So to go back to the original post, and to answer LSi's question, you WERE quite legal, plod was wrong in this case, (although I would suggest that his/her mistake could be an honest one mitigated by the misleading information available to them). So you DON'T need to sell your van and buy a Discovery!
As long as you don't exceed any of the specific weights on your plates, and provided the V5c doesn't give any maximum trailer weight, you carry on my friend.
If you get pulled up in the future and someone suggests that you are exceeding the max trailer weight, ask them under which specific regulation you are committing an offence.
This is not a grey area, or a loophole, it's just that it would appear that quite a few plods have been misinformed.
Read more at http://www.ybw.com/forums/showthread.php?226543-What-weight-can-I-tow#gY21xilmOubHIf0K.99
Do you have a source for all this?
If it's an old trailer and you cannot ascertain this information, we would suggest you don't use it
You can get a Nato Hitch with a load rating up to 12190 kg that I know of so as long as the bit of the vehicle you bolt it to is strong enough it would be fine. As for the legality on modern vehicles I have no idea.I would imagine finding approved towbars that would run trailers at nine tons will be a challenge.
The reply is about an unplated trailer, it wont apply to a vehicle.
I meant sources I could actually look at.
Each police force will give a different answer.
The C&U regs say the limit from the maker is advisory. The GTW is law. Not having one at all will get the book chucked at you.
I dont think justme is arguing, I think he is trying to help us and is willing to learn himself in this minefield area, I am VERY concerned as to the legalities of all this and there seems no black and white answers to thisSorry I'm not going to argue further,
