Richard.
- Cambridgeshire
The trays will likely be grade 304 so you could use 308 which is cheaper than 316.I'm not shy will always post pics if they are bad. Most are bad.
Now i need to buy more filler rod. 316L 1mm or 1.6mm.
Like I say you may not need filler for those but if you do 1mm would suffice.
. Bought another flowmeter and some fittings so they should both fit my reg and a quick release fitting so i can switch the reg between the mig/tig.
