Paul.
Moderator
- Northampton. UK
Yes they are the ones.A15 are ER70S-2?
I made a right mess of that.
I struggled with the tacking up the tungsten would ball up straight away i don't get it was not touching the metal.
Made a few holes when tacking up tried to fill them later and made them worse. I thought about getting the MIG out as i'm ok at filling holes with that
I found the outside corner joints the easiest.
Gone though 40 bar of 200 is that normal?
View attachment 93941 View attachment 93942 View attachment 93943 View attachment 93944
Sorry it didn't ball just rounded off after one tack. When welding a bead it would stay sharp.Your tungsten shouldn't be balling up on dc ???
I've now got an old leather covered seat that was a typists chair on wheels that I took the arms off it's much better than a solid base as when you get up , as you nearly always need to push the chair backwards to get away from the bench .
Being able to rapidly adjust the height from about 550 mm to almost 800mm high is also a very useful thing for it can be done whilst standing up with your butt almost on the seat cushion .
Having the gas struts air spring suspension system is much more comfortable than a solid stool especially if you suffer from back ache .
One other thing , . the castor wheels on the seats spider base are common to nearly any office type seat that's been made in the last 30 years so are easily replaced off a scrap office chair if they get damaged.
The width of the spider base is also slightly wider than the seat it also gives a 3 inch tall step to place your feet on it you want to . A final benefit ... I've not managed to knock it over in any of the ten years or so I've had it .
The gas strut died on my stool last year , I found a much better quality replacement gas strut / lift on-line in an eBay shop at a fraction of the price of a new chair supplier could supply or any commonly known eBay replacement places for ( £6.50 , delivered , May 2015 )
Do you have anything like the Freecycle movement or similar in your area ?
I hope to produce similar , but better than your's , sometime tomorrow .
They are coming on well Daz. Some of those look very uniform.
Now stop messing about with that steel, be a man and get some aluminium on the go.![]()
Any suggestions of where I've gone wrong on the DC TIG ?
I do have a snapped blade somewhere, will have to dig it outChicken !![]()
