I'd like a pedal but would probably cost as much as the welder.So are those worm holes at the start of the runs the reason why a pedal is a good idea or can the trigger on the wand eliminate them ( I don't have a pedal YET ! )
The craters are at the finish of the bead, they can easily be eliminated by using a bit of slope down and / or backstepping a little at the end of the run as per this video from the tutorial,
http://www.mig-welding.co.uk/tig-technique/tig-bead.mp4
Could you adapt a Stahlwerk one ? Only £26.00 NewI'd like a pedal but would probably cost as much as the welder.
You would do wonders with half a day professional tuition, any chance of that happening in Spain?
Yes that hasn't gone well but perhaps a step too far?
Your plate runs should be to an excellent standard before attempting joints on thin walled box on the plus side if you do get the holes filled you can linish those welds back and the actual item could still look nice.
Tacking is a skill in itself and one that can be more challenging than the actual welding when dealing with thin wall.
This is a case (should of mentioned earlier) when all slopes settings are better off tuned off.
Good fit up is key and hit it fast with a high current, get fill in immediately and come straight off.
Practice that till you have perfect tacks every time.
When you come to do your run turn your current back down to a level that's suitable.
Should be fine Daz. Good quality brand and ER70S-3 is a basic rod.
ER70S-2 is the triple de-oxidizer stuff, which is what you want if you can get it.
ER70S-3 is run off the mill bobby basic stuff, perfect for clean metal.
ER70S-6 has more de-oxidizers than S-2 and gives a wetter bead, copes with "dirty" steel better than S-3.
In practise neither of us is gonna notice the difference
http://www.harrisproductsgroup.com/en/Products/Alloys/Welding/Mild-Steel/ER70S-3-GTAW-TIG.aspx for more info
