pedrobedro
Man at Matalan
- CX near Chesterfield
What size Warco are you using?
Warco wm 240b .What size Warco are you using?
Out of interest guys. Is it OK to bolt a lathe on to a wooden bench. Providing it is flat and rigid enough.
LOL Mr shiney. I hear you about the washers.Similar to a Myford. Marine ply is very stable. Try it, you have nothing to lose and it will be better use of your time than making washers!!!
I no this sounds picky to some but the washers I oredered ain't what I would call quality. They are slightly off centre and have no uniform at all.No. Any torque at all on the hold down bolts will compress the wood and introduce a distortion.
If you're aiming at thousandths of an inch, stick a bolt into a solid block of wood and measure it with a DTI as you tighten it up.
The whole purpose of a lathe body is to maintain accuracy over a span and I can twist my Colchester measurably just by adjusting the feet!
Sure you can get away with it but is it OK? No. It isn't.
S.
So if anyone would like to machine me 10 washers. M12. 50mm OD . 5mm thick. I would be very happy. Cash waiting of course.I no this sounds picky to some but the washers I oredered ain't what I would call quality. They are slightly off centre and have no uniform at all. View attachment 92569 View attachment 92570
Not exactly a precission product are they, at 5mm thick I would have expected them to have parallel faces. I suppose the hardened washers you find behind cylinder head bolts would be too expensive ?Sometimes if anyone would like to machine me 10 washers. M12. 50mm OD . 5mm thick. I would be very happy. Cash waiting of course.
