Yes I agree. But The main reason I try to make as much as posible is the fact that when even I go to different stores or places to get washers or bolt ect is they never have what I want. They can't be bothered to order it.the washer on my tractor unit are 5 mm thick.so I have to replace like for like. If I can't then I will make.just the way I am. But have found a place on the net that have what I want so all good.Its a question of using the grey matter, spending 4 or 5 hours or more even, making something you can buy in the local hardware for a fiver is a fools errand.
I only ever make them if they're odd, like a stepped face to retain a spring or a really big ID. They take far too long unless you have a capstan lathe.
I was just intrest ed in how they are made on a lathe.and the tooling needed and used to perform the task. Am totally new to the lathe side of things.but look forward to doing stuff over winterI only ever make them if they're odd, like a stepped face to retain a spring or a really big ID. They take far too long unless you have a capstan lathe.
It's ok. I don't take them as negative. I asked a question and I appreciate people's opinions and there thoughts about hat I have asked.it's all goodI can't understand all the negative posts. If it makes you happy doing it, then do it. I do lots of things that have no real value to anyone but myself.
I will indeed Mr shiney. .thanksIt will cost you more to Tool up and make them than you will EVER make back. Use your lathe time to learn useful skills.
Thanks for your reply Rory. It will give me some practice over the winter and get familiar with the machine. I have a huge box of off cuts of different sizes and diameters so have plenty to get on wiyhThe way I would do it is this, chuck material up with as much sticking out of the chuck as you can get away with without too much overhang, face off, turn OD, centre drill, drill to required size , bore out if required. Part off to length and then keep parting off till you run out of hole.
If you fancy making washers then make some washers, it's your decision if it's cost effective, even if it's not cost effective it's good practice at the basic lathe operations of facing, drilling , boring , turning and parting .
What don't you like about parting? I never have any issues since I switched to a blade type parting tool and I lock the carriage before I powerfeed the cross slide in.Problem with parting off is it is the single most horrible chore on a lathe! (Next to cleaning it).
Parting off 5mm washers is going to turn more than half your stock to swarf and I dread to think how many busted parting off tools you'll end up with. I thought the superglue trick was worth having a play with....
S.
even on a new machine its more robust a rear tool post u don't get dig insHave a rear mounted holder for parting off on the Colchester works a lot smother than holding in tool post, it is an old machine though![]()
