Arc Tourist
- Wales
Are you kidding ?
Here's my show & tell for the day. There were only a couple of tiny nicks on the vice which I touched up with a file, and then painted it with my diminishing supply of "One Shot" sign painters paint. The metal label was removed as I don't like anything distracting. This is a good tool, and am glad the vice was treated very well by its previous
owner; and cheers to who ever it was.
View attachment 90731 View attachment 90734 View attachment 90735
Ferdig!!This new phone . I will not fix this .. Well now it has been in the water about 4 hours
I'll 90s scene it for you: a most bodacious and copacetic transformation.I'm lost in translation.![]()
Reply from the 60's
That's far out man.
40s reply... by jove i think he's got it.
The 1920's replay.
That's absolutely spiffing.
I see someone's fixed the Flux Capacitor......![]()
best vise
well spotted, but can we take it you fix it nearer the edge of the bench when in use?
yes there is one bolt missing, it is fixed, down at two points the bench top is an old door so I have it in the best position to get two good fixing points, will rectify when I can get hold of an old bit of worktop, it originally stated out as a tempory bench top solution three years ago lol, and yes dad would tell me off for not fixing it down correctly
u need the back jaw of the vice slightly overhanging the bench so long ish materials will fit up in to the vice
Yes, but if i move it forward I would only have one bolt securing it down as it is the edge of an old door, hard to describe without seeing it.its set back to far if its already bolted downu need the back jaw of the vice slightly overhanging the bench so long ish materials will fit up in to the vice
Right, I went back up the shed and realised if I moved the vice to the middle of my door bench top I could move it forward into the correct position, I even found the original bolts dad had it mounted with, see image, thank you guys for the kick up the a**e to do things properlyYes, but if i move it forward I would only have one bolt securing it down as it is the edge of an old door, hard to describe without seeing it.
