.Only if I drill through the frameAm i right in thinking there hollow..slide a nut underneath. Or post 2 or 3.
.Thanks, I've just ordered a cheap helicoil kit of eBay.
Only if I drill through the frame.
Just for the record my post of a nut was intended for inside the square holed sections...thought they were hollow and i never meant right "through" the tube2 x M16 bolts, straight through the frame, murdered up so tight it crushes the tube flat.
That's what would happen here anyway.![]()
Maker might be a bit stuck there Paul...John has,nt tapped a thread into a turnip yetAnyway, should you be asking questions like this? Don't you watch Doubleboost?![]()
I knew someone would comment on thatyour tape measure has very clear case to it !!
looks almost invisible!!
. The spring rusted and snapped but it's still a good tape
. It's not invisible though, you can see it in the corner, a tie wrap is all you need.I did watch him, until he started machining vegDon't you watch Doubleboost?![]()
.Best not, you might find out I'm not really a 17 year old with a dead tape measure and I have in fact been lying to you all for yearsI've just seen @Maker 's tapemeasure, the poor lad, it brought a tear to my eye, can't we have a whip round to get him a new one ?
( Poundland only, were not that generous )
