mangocrazy
Italian V-twin nutjob
- Sheffield, UK
Hi, I've been looking at various ramp/jack/lift systems to get vehicles off the floor and at a sensible working height, and I quite like the look of the ones designed by http://www.restorationramps.co.uk/ . They sell you the designs/plans and you either weld them up yourself or get someone to do it for you.
When I inquired further about this and asked about suitable welders, I received this reply:
You would need to use a decent MIG welder with an output of 180 amps or above with a wire size of at least 0.8mm, a hobby MIG is not powerful enough.The minimum steel thickness used is 5mm.
My welder is a Clarke 160TM, and I'd say that 5mm steel is right on the limit of its capabilities (if I'm being kind). What welders should I be looking at for a job of this nature? There's a fair bit of metal to stick together, so I'm guessing I'd need a reasonable duty cycle from a welder that can comfortably deal with 5mm steel.
