this tbh... as long as its steel parts.Mag drill with Rotabroches?
If using a rotabroach it must Depend how well the magnet holds with only 4 mm material underneath.
Not if you don't have access to a lathe.you could turn the shank down so it fits the chuck
Rotabroach Mini cutters willl fit in a hand drill and should cut through 12mm when using a 20mm diameter cutter.
