Hey all.
As a motorcycle restorer I often have to drill out broken studs, bolts etc.
I have a particularly tricky job on. I have to drill out some severely corroded exhaust studs from a motorcycle head.
The problem is, the studs are all at a 20 degree angle so I can't get a straight run on my pillar drill. I don't want to use a hand drill in this case as the margin for error is MINUTE..
So, are there any tricks, tips, tools or clamps that I can use to hold a fairly large work-piece and rotate and angle it etc ??
I've seen tilting vices but they're all very small. Seems they have a 100mm jaw. I need something with wide jaws. 200mm really
Thanks in advance.
Ted
Thanks in advance.
Ted
, but does your drill table tilt?
