Tried it. The studs are so corroded they won't budge. The nuts just keep snapping off. I've tried heating the head etc. I've tried everything.
CRIKEY !! That things huge hahah. Out of interest, how much are you selling it for ?? If you are that is.
This is where centre drills come into their own; start the hole off using them as they are far stiffer then swap to a jobber to drill through.As cautioned a drill press might wander because drills are a bit flexible, so if you dont get the angles perfect, the end of the stud ground flat first and get the guide centre dot on centre you can end up with it wandering off into the softer alloy material around and then you are into welding up the repair and retapping it. If its new to you, best have a practice go on that old engine lying round the back you dont care about first. Honda's are great for this![]()
291657077756Hey all.
As a motorcycle restorer I often have to drill out broken studs, bolts etc.
I have a particularly tricky job on. I have to drill out some severely corroded exhaust studs from a motorcycle head.
The problem is, the studs are all at a 20 degree angle so I can't get a straight run on my pillar drill. I don't want to use a hand drill in this case as the margin for error is MINUTE..
So, are there any tricks, tips, tools or clamps that I can use to hold a fairly large work-piece and rotate and angle it etc ??
I've seen tilting vices but they're all very small. Seems they have a 100mm jaw. I need something with wide jaws. 200mm really
Thanks in advance.
Ted
I've tried all sorts of welding methods. The studs are M6 and they are so corroded they crumble. I guess its worth another go using the blob method.
The studs did have thread protruding when I got it. I put as much heat into the head as I dared without warping it. They still wouldn't budge and would crumble. Once the 'crust' fell off them they were more like M4's..
I went to remove the headers on my 1996 Bandit yesterday, and all eight of the bolts sheared off at or just below the head. This is my third Bandit and I have removed the exhaust off all three for the same reason - rotted collector. Here is how I went about tackling those 8 broken studs. Forget easy-outs and stud extractors for frozen-in bolts, you will very likely only make things much worse.
There are a couple of tried and trusted ways to remove a stud that has some thread showing.
One way is to put a nut over the stud and weld the end with a mig welder getting it nice and hot, then un-doing the nut which should bring the stud with it. I don't have a mig welder - I have an arc welder but they are much harder to get good results with since the rod is fatter and for small diameter studs it's likely the arc will wander when you try to weld in the well of the nut.
The other way is to drill out the stud. This is no easy task, starting off on the end of a sheared stud is tricky and you must be dead centre to avoid having the drill wander off the bolt into the softer ally threads. This is how I have done it - by making a drill bushing.
First, take an old 12.5mm drill and chuck it up in the lathe backwards. Drill bits are not hardened at the shank so you can drill, file and cut them but they are made from hardenable steel which is what we want. Drill the tail-end 6.8-7mm which is tapping size for a M8 bolt.
Then drill it deeper with a 4mm drill, which will be the pilot for drilling out the stud.
Now I set up a M8 taper tap in the lathe using the centre to keep it perfectly in line.
And follow it with a 2nd tap and plug tap to get the thread right to the bottom of the hole.
After that I part it off.
Now I need to be avble to tighten this bushing, so I file two flats in it for a 10mm spanner.
Broken studs.
Bushing fitted
I used the drill rod so I could harden the bushing for use. This involves heating it up to cherry red and quenching. Here is what I did, but unfortunately I could not get it hot enough on my gas ring to lose it's magnetism (which is when it becomes hardenable) so it remained soft - so I used it anyway. Tomorrow I will take it to work and heat it with oxy-acetylene then it will be glass-hard.
As you see, the drill now takes a straight path directly dwn the middle of the stud.
Drill extension for those hard-to-reach ones. Just a bit of mild steel rod, grind four small flats on the drill you use to drill the rod with then poke it in and give it a little squeeze in the vice.
Holes drilled, spot on centre and right through each bolt - only 6 more to go.
Once all eight are drilled I will follow the pilot with a 1/4" or 6.5mm drill to allow me to pick out the remaining threads.
Did some more tonight. 6.5mm drill down the middle:
Too small as it leaves the thread intact, though it looks pretty cool. Tapping size is 6.8 but I wanted to allow a bit of extra clearance so I went for a 7mm drill. Tapped using a 1/4" socket extension backwards in the tap wrench to reach past the frame. You need a GOOD tap to do these:
Both done and bolts fitted:
Middle ones will have to wait until I get some more 4mm drills![]()
What's the head made of? I was impressed by this the other day:
I'll have some what he is on...lolWhat's the head made of? I was impressed by this the other day:
It almost seemed too simple when I watched the video so I had a Google and there were quite a few references to using it for removing broken taps and such, I think the main problem is you need to make sure the solution can't touch anything else iron based or it'll corrode that out too!I wont touch exhaust bolts anymore, more hassle than the jobs worth.
If this works as good as that video, then its worth a try, heads already off, make a solution and dunk it in. Happy days
