- Birmingham
What was the magmount on a biscuit tin or a radiator![]()
I used a 2 metre magmount on a radiator as a temporary fix for a couple of weeks, could work all my local mates OK
I went through hi mid and lo and both Am & FM And nothing 240 channels of nothingwhat u on am ??
PL 259 plugged inI went through hi mid and lo and both Am & FM And nothing 240 channels of nothing
damn I knew there was somethingPL 259 plugged in![]()
Caroline ?My lad had loads of kit. He was also a Radio Ham and they used to send stuff over the waves to a printer. Im not exactly sure what they were, sort of calling cards with their number on etc.
I had to take him to somewhere near Mablethorpe to sit an exam.......Radio something.........there were a few there, all about 50 years older than him.
ive even just pulled the coax back off the aerial and tested for continuity and its good, so apparently the airwaves up here are deadPL 259 plugged in![]()
Or is it just you have a 10-1 set upive even just pulled the coax back off the aerial and tested for continuity and its good, so apparently the airwaves up here are dead
if it is, its all 3 rigs ive just triedOr is it just you have a 10-1 set up![]()
first I had to find the magmount and when i did the whip was missing then search through the loft for CB's mic and power supply then onto hunt the whip, which I eventually found behind a pair of subs after moving other pa speakers guitar and bass amps and a set of drums, then had to rewire aerial then rewire power lead into CB only to find there was not a soul to be heard over 240 channels, you've wasted my time
me mate had a superstar 2000
http://www.rigpix.com/cbfreeband/superstar_2000.htm he still has it new in box
kayos you are a bad man, starting this thread bringing all this nostalgic CB lark back upfirst I had to find the magmount and when i did the whip was missing then search through the loft for CB's mic and power supply then onto hunt the whip, which I eventually found behind a pair of subs after moving other pa speakers guitar and bass amps and a set of drums, then had to rewire aerial then rewire power lead into CB only to find there was not a soul to be heard over 240 channels, you've wasted my time
No couldn't find swr so didn't tryDid you call at all? Maybe there was loads of people sat there thinking "well there's nobody on is there???"
Go on give it a go, I've got plenty of 1969 final output transistors!No couldn't find swr so didn't try
I'll give that a miss thanksGo on give it a go, I've got plenty of 1969 final output transistors!![]()
Alternatively, do what I did.
Take exams, be allowed to make your own radio kit up to 400w on frequencies people actually use![]()
