Parm
Respect The Sound System
- Towcester
How long do you estimate it will take to drill a single hole into masonry (Plaster over brick/block work) with a 5.5 mm diameter drill bit used in a Makita LXT 2Kg masonry drill set for rotary hammer action. The holes will be deep enough for a 4x50 mm wood screw and wall plug.
Im estimating from previous experience that this should take no more than about 10 seconds per hole
Any suggestions please
thats spout what I said
Ah well you see -------you need train-ing to drill them
chase the drill across the floor
