- Birmingham
Check your radiator(s) while the front end's off as it's the best way to change them...
then try and restore some colour to it with the heat gun
I used it as a trial on my last car - restored colour and shed/beaded water, but I can't remember what durability was like [it was c. 4 years ago.....]
Lots of tips like that over on DW - http://www.detailingworld.com , but have a cuppa and plenty of time before you go there![]()
Good truck, nice project, good price...
???? looks like the apprentice did it 3hrs !! i had one freelander that had a bad alternator at some point and boiled the battery which put battery acid in the grommet ( forms a little cup) for the nsf brake pipe, just under the battery impossible to see, but rotted the pipe through in one precise spot, the pipe was perfect every where else, bar for the 10mm in the grommet and it burst!!it seems it was a bit of a pain as it took them over 3 hours......
No DAB?Minor update, front end all nailed back together and just waiting for some bolts as the under tray was held on mostly with optimism, i've put more bolts in but I want matching
Also this
Freelander-9 by Stuart Burrows, on Flickr
I know its not important to some, but i've had this head unit from new in 2010, its fantastic.
Digitally connects to iPod and uses its on board DAC's
The standard speakers are rubbish but if the car behaves over christmas it will be getting a full SQ Alpine and DLS install
No DAB?
External TX needed for the head bolts...
