Ben88
- Lancashire
Ive never done a square to round but would like to know how it's done, I presume that you would be given the height, length, width & diameter and that it would be done in 2 halfs? I think i remember reading that you draw centre lines in the centre, draw a circle at needed diameter split half of the circumference into 12 equal parts same on other side of circle then draw your length & width of your square using your centre lines as reference with the circle in the centre on the square then join your radius marks to each corner cut out the diameter, then fold on each of those lines lust over 11 degrees each segment which should leave each side at 90 degrees. I imagine im very wrong????
