scotto75
- Bristol
Hi,
I'm doing some minor modifications to a Honda motorcycle frame. I've cut the rear of the frame to weld on a loop, not too much cut off to start with, but it looks like the frame is made up of two lengths of tubing, with the OD of the inside tubing being tight on the ID of the outer frame tube.
I can't find anything that references this except a very brief blog post here...
http://www.chinonthetank.com/2013/01/how-to-cb750-rear-frame/
I tried to get a chisel on one, as per the advice in the blog, and see if anything happened when I hit, but it's pretty determined to stay in there. I'm not even sure how far it goes? The only other idea I have is about making a small cut around the frame half an inch in and knocking off the outer frame tubing to expose the inner?
Does anyone have better ideas on how I could get it out?
