They do seem a bit weak. Thought about trying the trick to remagnitize with a arc welderNice bike, have you checked to see if the magets in the flywheel have any go left in them?
another job for a multimeter test the voltage coming from the coilThey do seem a bit weak. Thought about trying the trick to remagnitize with a arc welder![]()
Is your mist green in colour ?
Not familiar with that trick, I'm keeping an eye open for a magnet charger to sort out the Lucas sr1on my Howard.They do seem a bit weak. Thought about trying the trick to remagnitize with a arc welder![]()
It very hard to sit on. On top of this the rear brake pedal was behind the foot pegs. There was no way I could work it with my heal as it seemed impossible so I have now moved it in front of foot peg, still hard but I may have a chance with it now
It also had a short hand change gear leaver as well as a rocker type foot operated leaver. I was told this was to aid with push starting, there was no kick start. It was stuck in gear when I got it and I needed to get into gear box so have removed the foot change as was welded on the gear change shaft so I could get in gear box. I can now with a bit of work fit a kick start as I am sure with this riding position there will be quite a lot of me stalling it and don't really want to be push starting it every time
A sunbeam s7, thats not a bike, thats a gentlemans conveyance ! Is your mist green in colour ?
The S8 was never made in green and never had the big balloon tires, also had a smaller front end.
I came across a trick on the web that by using a electric drill to spin the engine for 5 mins without the plug in this would basicly put any charge produced back into the flywheel magnets. Anyway did this untill my electric drill was smoking hot and almost burnt out
and after some other very fine adjustment did manage to get the smallest of sparks at the plug. It is though weak and can only jump a gap of around 1mm but at least I got something
The spark is the same at the point the plug lead connects to the magneto and at the end of the plug lead so I do not think any of those parts are the problem. I do know that under compression a week spark will probably not happen and this is probably why engine not firing up. Would this point to it being the magnets or the condenser at fault? and not the coil. I have taken some photos and maybe someone can ID the make of mag I have as that would help.
It looks like a villiers flywheel magneto haave alook at the drawing on this page
http://www.historywebsite.co.uk/Museum/Engineering/Villiers/Villiers3.htm
