In fact Ford say that certain heads should not be skimmed for this reason.If it was causing problems heads wouldn't be getting skimmed at all.
how can you say that ??It's retarded, pump timing is out. Bosch or Delphi pump? Bosch, do rear entry method, delphi, side entry with 90 degree adapter.
so what does that prove / it will still white smoke if the clearances are tight because it is still unburnt fuel, it would have started on easi start if it was just retarded because that has nothing to do with timing and all to do with compression.It started with a tow and is puffing white smoke,
Some XUD-9 don't have the hole in the bellhousing for the crank locking pin in my experience, he might have it a tooth out.
It's a single cam with a keyed sprocket so can only be in one position and has a hole which you bolt it to the head and the pump has two bolts all have to line up for the pin to go into the flywheel so i can't see how it could be wrong
Hi, the thing is skimming heads is a historical practice from the days of side and overhead valve engines which are more tolerant of this. Just because it's been done in the past does mean it can still be done regardless. OHC engines can and do especially Peugeot for breaking cams and cam caps or carriers.
Colin
Ford say that only on certain models.Norm, as for Ford saying you can't skim their heads - well they will say that wont they,
19 thou is a decent amount by its self and I doubt that it only had 1 thou off it the first time so you can bet that the camshaft bearings are out of true whether they have worn already allowing for previous warp who knows it's a gamble some pay off some fail, I've had heads skimmed with no problems but there is always that chanceFord say that only on certain models.
Well yes we do skim but it is not always the 'correct way' hence A/M head savers etc but the fact is you cant argue the fact that cams dont break, coz they do, the old vauxhalls were one that did it regularly, after a head warp and skim, it is a chance you take, by your previous posts, you respect Eric Hammonds, work, who i do do work for, ask him his views on it, as said, he and I have discussed this at length and ways of getting around it.
It is a fact that doesnt go away. I have only had a couple but I will say that I try to check for tight cams.
It is my view that, Customers should always be warned of the fact that this could occur, in case it comes back to bite YOU the garage owner on the backside, after all it is not your fault they overheated the car in the first place. But it is your fault if you dont warn them.
It is my view on colneroy's historical point was, that in the past mechanics have just had the head ground flat regardless how much, that being on low cam pushrod engines, because there is nothing running in the head and is usually no problem, and that factand practice has stuck.
Now You should not just have a head skimmed regardless because of the fact of warp-age. and in fact 2-4 thou is the max in reality after that you are well into the realms of bending cams. Now this head has been skimmed before and we dont know by how much, and now has had to have 19 thou off it to flatten the face, that means the head is bent at least 20 odd thou, you do the maths.
I was following the instructions i have and with the head off 1 & 4 were at TDC as they should be.PS
I have never put a pin in the crank on one of those or most engines tdc is tdc, they are usually a pain to get to, I check it with a vernier with the head off and tipex front end, simple, or if it is impossible with the head on I have a snap on tdc finder or the old way is to fill the cyl with oil and watch at the injector hole then wash out the cyl afterwards with diesel
Of course it is it's an LDV! If they had stuck with Ford engines I might have stood a better chance and the short time I did in a pug dealer I drove a Boxer but only ever topped the fuel up everything else was done in the workshop the bit I didn't work in the 11 months I was there.![]()
Will check Autodata tomorrow, see what it says.
1-you must use a pin through the front of the crankcase behind the starter to lock the crank
2-does it have one of the injectors with a 2 pin electrical cable on it,if so did you put it back in the cylinder it came from?
tappety?this is valve to piston interference- see (1)
also check the keyway on the crankshaft gear as theres an issue with them shearing
just friendly observations,as i used to work as an engine technician/builder for a reconditioners for years.
I haveWill check Autodata tomorrow, see what it says.
By that statement Are you now saying you didnt pin the crank?I was following the instructions i have and with the head off 1 & 4 were at TDC as they should be.
No I didn't only thing I did at the pump was loosen the unions to move the pipes out of the way and then bleed it.did you have the banjo bolts off the fuel lines at the pump? did one look different to the other?
