Please tell me you didn't do that in one day? My god that'd take at least the whole day I'm sure haha.Awesome just awesome,
I have read this from page one and I'm gob smacked at both the quality of work and write up.
Great work Kim will be back for future updates....
I think you should stop showing off now smartie pants!you're doing fantasticly miss Kim!
Look forward to the next installment![]()
That's he plan, hard doing anything in this four weeks of the year as I have so much on. But I'm finding ways toIf you need any incentive to getting it finished just remember what its like working outside in winter
I am sure that with your rate of work and dedication you will have it finished long before Santa arrives.
Oh I wish haha. I say it's more of a blog that everyone replies and helps me withSanta may NEED to come to bring some of the parts Kim needs to buy to finish this project - unbelievably pricey doing a job like this and it always goes over budget.
I reckon the thread needs converting to a subscription channel to pass the hat round for her![]()
I rewired a series 2a from scratch. The old loom was piled in a heap on top of the engine and it had been running like that![]()
Down boyYeah we're all looking forward to seeing Kim get all mucky again![]()
(makes a change I hear you say
luckily the pipe cutting tool allows me to cut just behind the flare making it much easier, I did do it about another two times though
anyway got that sorted and on with the other side done. Just need to buy some more clips Okay I'll go to a shop and try get some thanksKim, a decent active flux will remove an amazing amount of oxidisation. How much would a new loom be? In fact are they even available?
I've been doing exactly this. Unlike before I will be able tying it tight to chassis or something and in a way it's not going to do this again and won't have any way to move. Also will be shortening the tow socket loom as its way to long currently. That should reduce the amount of loom lying around.Soldering the loom should prove to be a good short-term fix but you might encounter problems later on because you're creating a hard spot in a flexible lead. They tend to break at the end of the solder joint especially if there's a lot of vibration. Make sure the repaired section is thoroughly supported so there's no movement. Some self-amalgamating tape would be a good idea to re-cover the loom wires and keep out moisture.
On wires that have been abraded like that and exposed to the elements I usually try going a couple of inches further back on each wire to see how far the oxidation goes then add a fresh section. Sometimes easier to replace a whole length if you have the correct colours.
