I'm not going to argue with you as I daren't Google 68mm straponsWell if that is rainwater its 68mm dia there are no strapons for that size.
Rainwater is push fit with no seals and not normally solvent welded "So it is a welding thread"
I'd let it run to ground KISS keep it simple stupid
Perpetual motion of humidity and dehumidity? I like itwhat you could do is what they do with fridge freezers, run the condensate in to a SS pan thats sitting on something that produces waste heat, the water will now just evaporate into the atmosphere - simples
verrywhat you could do is what they do with fridge freezers, run the condensate in to a SS pan thats sitting on something that produces waste heat, the water will now just evaporate into the atmosphere - simples
and put the condensate back in to the air where it was removed from
Perpetual motion of humidity and dehumidity? I like it![]()
Mmmmmm, best to do the job right first time no messin. I would say the way forward would be to forget the dehumidifier, it is too complicated and potentially dangerous.
Best thing to do is get one of those free energy hydrogen kits off of ebag-no energy costs there. Vacuum out the air and hermetically seal the H unit inside your garage and attach a long rope and extension lead to the corner of the block-work. Eventually the Hydrogen will lift the whole building up and high into the atmosphere where there is a lot less moisture thus curing your condensation/rusting issues. When you want to do some welding just pull it down again and immediately get in and start welding-nice dry mig wire'll feed through lovely. Job's a good un.. Flawless plan so please no nit pickin, it won't make any sense you know.
The pipe will poke out on to a bit of waster land, owned by us, that nobody overlooks. So that seems the easiest solution.Shield gas is inert. No nit pickin!!!!!!!
But in an effort to assist the question, you will draw a couple of litres of water a day so trickling it out to a bit of waste ground won't cause a problem. On the other hand the neighbours may think you have installed a dodgy toilet with an overflow and call the council on ye!
Eh?collect water in a bucket , empty said bucket once a day , job done !![]()
. Ok what is it,fool or genius?
It's clean water and above ground, it will not trigger the apocalype.
