roofman
Purveyor of fine English buckets and mops
- North West with water on 3 sides
yes very correctamundothey are also very handy for changing valve stem seals or broken valve springs without removing head.
take the oil filler top off and the dip stick out or you run the risk of blowing the front and rear main crank sealsI like that - a quick blow job![]()
but if you take the oil filler cap off then listen to how much is passing the rings compare with the good ones
looks like your making progress in finding the running problemRight, another interesting evening! As suggested I dismantled my compression tester to create an easy method of putting pressure in the cylinder and I wound the pressure down to about 50psi. I started with #2 as that had the lowest compression. On TDC (compression), exhaust valve clearance was 0.3mm and when applying pressure there was a leak through the exhaust port (I've taken the exhaust manifold off). #1 was 0.45 and on applying pressure it moved the piston down, #4 was 0.2 (but no leakage and #3 was 0.5 and no leakage.
My regular engine re-conditioner in Westbury appears to have gone off line (telephone gives unobtainable), however a place in Bath with cut the seat, grind the valve and skim the head for £56. So I think That's the next step.
I'll let you know what happens next!
Cheers
Peter
Cheers
Peter
specialists my a**e--------- VERY special IMOIt was at a specialists for the last few days and they even had an external specialist look at it!
That was a good guesshose in the number2 then blow regulated air pressure in and see where the air is coming out my guess is the exhaust valves
Before you take the head off open that valve by putting it on full lift if you have removed the ex manifold borrow a bore scope ( endoscope) and have a look it might be something stuck to the valve seat it could be small lump of carbon etc.Compression test shows all cylinders are OK.
Funny that i've never needed to do thatstick between your legs when blown up and bragg to the missus.
more often than not you need to knock a tool up to fix into a cam cap bolt thread or a rocker and get a fulcrum going to compress the spring...its amazing what you can knock up if its a choice of removing the head or getting around the problem of a lever tool with a camel toe end on itI've never done this trick of pumping up a cylinder to save the valves dropping in, and can't figure out how one would compress the valve spring enough to get the the collets free of the top hat? I can see the valve staying up once its all removed, but valve springs can be right tough even with the head on the bench.
