thing is if it's a record it will be a rather rough casting so if you paint it with smooth paint it will show all the rough bits. better off with hammerite on castings
Good to hear you do it that way Matt. I've seen a few of your restorations on here and they look fantastic - it's exactly like that I'm aiming for.I just get my enamel from the local auto paint place Eschen. I go with their mid range one. It's a synthetic poly., satin finish. Seems to hold up quite well. 15Line I believe is the base manufacturer.
That's one area where I tend to differ from most. I love to see the surface roughness of cast pieces. I stopped using primer mainly for that reason, as it made cast look way too smooth for my liking. I just apply enamel straight to the cast these days. It's one of my little quirks.![]()
The little fella has no markings I have two. the other is slightly larger. it is most likely to be made in Poland just after the war. beautifully made same quality as the bigger ones
Joking aside, I think you'll like the look of straight enamel onto cast. Just make sure you wipe the cast down at least twice with mineral spirits or suchlike before painting. Heating the cast up somewhat helps too. That'll help get any trapped moisture out and also make the enamel flow better if you apply it whilst the cast is still warm. I usually stand mine in front of an electric fan heater for a few minutes, if I want to warm them up.how do i post a new thread
here's a Woden number 1 4" jaws a bit dusty it's been on top of the cupboard for ages
post new thread...go to the chosen section and click on the " post new thread"how do i post a new thread
Interdasting, I've never seen one like that before.
