ihave a set of five and none of them have flatsI think most silver & deming come with three flats, I'm very surprised your 60 mm bit didn't.
there ok if u just take cuts with smaller drills 1st then work your way up and even then they dont like itihave a set of five and none of them have flatsthere ok if u just take cuts with smaller drills 1st then work your way up and even then they dont like it
and a dividing headbrightspark, may I draw your attention to your posts in the thread titled "who needs a surface grinder anyway? "![]()
it wouldnt be worth the hassle of sourcing gears and making the fittings and countershaft ect to alter it for the odd large hole to be drilled .the cost of gears alone make it a non starter
Cheers, I don't want to part with it as it's a solid old beast. Will ask around for a set of back gears, but there is a better chance of politicians going legit than finding a set. Will keep an eye out for one of them sealy drills, but my workshop space is limited. What did you mean with reverse switch? Is it a 3ph drill?
Where do you get a reverse switch for 8 quid??No, just a single. The switch is a handy addition when tapping, and for around £8 I can't think of a better value item.
Paul G
wow you replied before I asked...lol8 quid off ebay from china
easy to work out when u can test with meter though i only use mine for on or off . i just hand crank the spindle if i want reverse u have more controll and can use it for tapping threads
Cost nothing, as I had the extra motor in the shed, complete with pulley.
