Nice score!today i discovered a pile of cast iron drain pipe so i liberated 4 lengths at around 5 1/2 - 6 feet in length, i also found a nice bit of grid type metal drain sorta stuff, i shall be returning for more pipe once i get a corner cleared for it. used a bit of the pipe for my woodburner chimney..
View media item 7976View media item 7975View media item 7973
yes mate very happy bunny when i found the pile of old pipes behind a disused building on the site we have our railway.Nice score!
Dunno about cast but black enameled is sixty quid for a bit two foot long from Crosslings![]()
I know. Still can't sit down from the stinging.
need to angle it and fashion a flange to bolt into my chimney. Rented property and I want to be able to take it out should I need to.
Tell me about itsounds like you are getting well shafted there mate![]()
If its 3 " bore its no good for a stove flue, unless its a tiny one.
Any fire box smaller than 10" cubed is a waste of time for wood burning, in my humble opinion. And that needs 5 " flue.
I've revised the plan I had a month or two ago regarding putting a small burner in the shed. Decided that with the farting about I'll be doing making a spot for it, it'll make little difference on space consumed if I just shove something larger in there instead, so there's a 47kg propane bottle which is going to be sacrificed. Going to fill the bottom half of it with sand, to both weight it down and to retain some heat once it goes out, and then just sit a piece of 4-1/2" thick wall steel pipe on the top of it and go straight out through the corrugated metal roof. It's sealing that bit which is going to be the pain.Now that we're going off on this tangent in the thread,I've revised the plan I had a month or two ago regarding putting a small burner in the shed. Decided that with the farting about I'll be doing making a spot for it, it'll make little difference on space consumed if I just shove something larger in there instead, so there's a 47kg propane bottle which is going to be sacrificed. Going to fill the bottom half of it with sand, to both weight it down and to retain some heat once it goes out, and then just sit a piece of 4-1/2" thick wall steel pipe on the top of it and go straight out through the corrugated metal roof. It's sealing that bit which is going to be the pain.
The bottom of it won't get hot.
Nice one! Is that from the bay? Been looking for some double glazing for ages now with no luck.today i collected some things i won at auction on wed
i got 3 no 6' by 3' upvc windows for the storage unit above the garage wooden ones are a bit rotten lack of paint
and this
and it came with one of these
and it works!!!
got the lot for under £40
