Maker
Most folk just call me; Orange Joe
- Keeler crater
Today I took the the vertical head off, there's no draw bar, it just unbolts from the front and wiggles out. Getting it back on was a struggle, you have to line up the drive slot thing and hold it in position with one hand and get the bolts in with the other. It has a Morse taper by the way.
I loosened the drawbar on the top of the vert spindle and have it some good hard whacks with a copper hammer but to no avail so I tightened it back up and left it.
I took the change gear cover off the front and found that I have the 39 and 25 tooth gears which will give me either 1.8 or 6.5 inches per minute, depending on which way around I put them.
I took the coolant pump out and started to clean that up, there was loads of coagulated crap blocking the inlet that had to be scraped out. With all the coolant and swarf in the sump I took out as much as I could and I've got it in a bucket, how should I dispose of it? And to clean it all out, can I use water or do I need a different solvent?
As far as I can make out, the motor will only run on 415 volts ( the piece of paper says at the top "for fractional horsepower motors" and this is 1 1/4 HP and I can only see 3 contacts anyway so it looks like my options are an expensive 230 to 415 volt inverter or a make rotary phase converter with 415 volt output.
Will any motor act as a generator when the shaft is turned or will I need a special one?
Has anyone on here ever built a rotary phase converter that could share some advice with me?
. It's one of the bolts that locks the double swivel head. There's three blocks inside it that have studs sticking out onto which a nut tightens, stopping it from moving. Well, the stud is screwed into the block and a tapered pin goes through the thread, creating a weak spot
where it inevitably snapped. Luckily it unscrewed and the thread in the block is still perfect. I'll probably be fine with just two bolts holding it but I'm still gonna sort it out. I'll post pictures later
