The point is that when fitted onto the tumbler lever, the tumblers should spin freely by hand, now due to being oversized,wrongly profiled or whatever, the New ones will not turn freely at all, to the point where the 28t is pulling teeth from the 30t, WITHOUT bei g fitted to the machine in any way shape or form. So I understand where you are coming from danielw, but the spindle gear has absolutely zero to do with it , not being anywhere near at the time the gears are stripping
You could mould some Polymorph against the good gears as a guage!
http://www.maplin.co.uk/p/150g-polymorph-n58ch
And thereby lies the problem IMHO. The issue here is no one knows how the old gears got broken. Most likely a crash and rapid stop I would think. The new ones are breaking from the information I can see when they rotate even if OFF the lathe.Ask DoubleBoost for video lessons
Definitely not the same tooth shape, on your 'new ones'
I don't know but I would have thought the meshing would have been done via the adjustment knob on the tumbler lever when it engages into the slot ie it adjust to put less pressure on the tumbler gears?
i would be tempted to set about the wheels you have with a file
Some night time reading.. http://bbs.homeshopmachinist.net/threads/33429-Phenol-Tufnol-gear-blanks It wont help much but its a good read,.
id do some serious measuring with the new ones when u get them before useSpoke to myford, they are sending a pair out again and have asked me to return the others for testing
I bagged my self a super 7 the other week, the only issue with it being the tufnol 30t gear had stripped on the lead screw tumbler , I rreplacedthem both with a pair from myford, pressed the studs in with about 1/1.5 mm free play as not to nip them, however I span the lead screw on the hand wheel and its stripped the 30t again. It did seem particularily tight too, with a fair bit of gear chatter. Any ideas?
