According to the units I have used the percentage value given is the percentage of time spent in DCEN (penitration) so if according to what your saying 30% is max DCEN on that machine then that tells me the other 70% is DCEP (cleaning). This is backwards in comparison to the units I have used. I don't suppose it matters really.But thats what the manual says........30% is max penetration. I need to fire mine up. lol
AH Ah I think I understand now. i will clarify it all tomorrow.View attachment 46475This is the balance setting on a typical ACDC machine . The 70 is 70% of the time spent in DC neg so you only see the figure DCEN the % remaining is DC pos. RTech case is the other way around from the sound of it. You would set the DCEP .
AH Ah I think I understand now. i will clarify it all tomorrow.I thought Double boost would pipe up but he is probably videoing again. lol
It is too thick really because your gonna need a 100 amps plus just to break out a puddle . 1.6 tungsten really is on the limit at 80 AC amps.What were the tig settings please?
I had no luck with a 1.6 electrode but that was on 3mm sheet, maybe that was just too this.
If you have the R-tech AC/DC TIG a good base setting for 3mm is:What were the tig settings please?
I had no luck with a 1.6 electrode but that was on 3mm sheet, maybe that was just too thick.
What differences/alterationsIf you have the R-tech AC/DC TIG a good base setting for 3mm is:
You would set the same values they just may be in a different place to what was said above. Go with 100- 120 amps for 3 mm
From my experience cleanliness and prep are the most important part. Followed by comfort of your position.Same values ok cheers. From my limited experience the setting are the be all and end all of welding. I was welding the other day and my welds were really clean and flat forming a triangle in a 90 degree weld. Today its taken me almost till the end of what I was welding.....all of this was because my son had popped round and altered the settings without me taking a photo....lol He was welding a car exhaust. (This was with Mig btw but I am sure the principle is the same settings are crucial)
AC balance at 11 o clock
Frequency at 1 o clock
A no. 7 or 8 shroud
A lanthinated or Zirconiated 2.4mm Tungsten ground to a sharp point, like a dart.
Argon at 4 to 6 LPM on a flow Meter
Post gas at 5 seconds
Amps on Max and controlled with a pedal.
Turn everything else anticlockwise and make sure its switched to 2T.![]()
Turn up the AC frequency that will narrow the arc down and it will be more focused.Thanks for that, it seems to work much better on those settings.
One point - when doing a fillet weld, how do you help focus the arc to the root? I find it's jumping left and right and really have to boot it to get the root hot, then I find the filler rod melting before it gets to the pool???
That is simply fantastic.....Having just this week got one of these fine machines set up , this thread has proved invaluable - untill a few days ago I had done a whole five minutes of ally welding.......
I scrounged some 1.5mm off-cuts from my local sheet metal place , and while it would be fair to say I should get better with time - today I did this......
This was with a 2.4mm white tungsten , 2.4mm 4043 filler , a foot pedal , and these settings -
Thanks for all who have chipped in on this thread !
