Would be neater to fit the consumer unit in place of the isolator. What's going to/from the isolator at the moment? I see three cables, which look like SWA from the consumer unit, then ring out for the sockets? If so and if the SWA is continuous you don't need an RCD at the supply end so could either have an RCD main switch in the garage consumer unit, or separate RCBOs for the two final circuits. How big's the SWA?I'll add a small consumer unit with a 16A MCB and an isolator switch with a 16A plug outlet. Can come out of my red isolator switch.
