Triumphman
when i bough my old colchecter triumph i intended to remove the three phase motor and fit a single phase one. this never transpired so now I am refitting the original three phase motor and fitting an inverter.
Seems pretty simple but I took the three wires off the motor and now (a year later) I don't know which of the four terminlas to put the three leads on.
I have enclosed some pictures.
one showing the motor plate
one showing the 4 terminals and 3 red leads
one showing the four leads i need to put in the inverter.
The wires ito the inverter are straight forward i imgine, but what happens to the earth? they'll be live, neutral and earth (13 amp) from the mains into the inverter, then 3 phases and a live from the inverter to the lathe? correct? theres no earth going to the motor so presumably this drops off at the lathe switch.
any help would be great.
also if you only have one earth connection on the switch and it come loose you have no earth.
