I've not got it (the gear) back yet, they're charging me £20 to fill and hard-face the damaged bits. Then I've got to grind it back to size.
That's a thought, don't see why not. I suspect ordinary mild steel would be OK for that job.
Maybe some of the magic metal compounds would be OK?
Another possibility, (depending on whether it's arced gouges or just several drill holes), would be drilling through the table, tapping and studding the holes then grinding flush.
.... You wussed out on the adaptation bit though.
apart from welding them up with arc cast iron rods and grinding them back u could fill them with belzona metal repair its grey in colour and as tough as hell nothing looks worse than a table that looks like swiss cheese![]()
The gear would have to be annealed, machined and re-hardened. More expensive than it's worth!
The instructions make it quite clear about not changing gear when it's running, but even when starting in gear there is there is the potential for a substantial whack. Graham's method of giving the chuck a twist before starting is the simplest way, as long as you remember!
