mig low amps mod,
are there any to get lower weld amps?
eg, welder has a range of 40A-180A ,
are there any mods to be done easy ones to get a low end amps?
ie, 40A down to 15A
bit more info would be good
what type make of mig and a picture of front panel insides etc
but doubtful to get it to go lower see my next post
let us know once you get your welder how you get on with this
Also mention of LARGE capacitors being added to improve ???
Spending far to much time reading posts
You could try making up a lead much like I did to go from the output of a 240 to 110v transformer (like Wedg1e was saying) one of the yellow boxes used by builders ( lots of builder gone over to battery tools now). Lead will need to have one of the round plugs to go into transformer then short length of cable then a 3 pin socket that you can plug your welder into, thus supplying it with 110vac. You would prob have to use higher settings as you are on less voltage. I don't know if the above will work for a welder but if you can borrow/get cheep (boot sale?) the yellow box then worth a try. I use the above as a speed reducer for angle grinder and a router for use on car grinding/sanding/cutting. You do have less power (that's the ideal) and it makes for quieter grindinglet us know once you get your welder how you get on with this
