- UK
I had a crack in the block on a Perkins 4203, the recommended repair was metal stitching, although I replaced the engine as that was cheaper.
Cast iron presumably?
I don't know if you have this but here goes http://www.fordson-dexta.de/downloads/section4.pdf.
It's called a tractor winkie, most agri spares places have them in stock but you have to ask at the counter.![]()
What does this tap do. Water wee's out when i open it.
Its under the fuel filter. Can be seen on the shiny pic above too.
syphon guns are ok for small parts cleaning for light paint and corosion if your in no rush anything bigger pressure fed pot is bestAre these tiny little blasting jobbies from the likes of MM much cop for blasting these little parts?
We have a place that does our blasting but i think their set up may be a bit harsh for this little stuff![]()
i have the 90cfm comp and pot using 6mm jet the grit is 075 to 1.5mm grit cos i can buy it cheap localyThats it really, is suppose it beats using a wire wheel on a grinder, plus it will get in the corners.
aluminium oxide best for cleaning paint/rust/grime off steel/cast iron/tin parts?
but to be honest it laces steel parts and is 2 corse superfine would be best or as said aluminium oxidethe aluminium oxide can be re used over and over expendable only about twice and is messy just sieve the dust out of itCan the media be reused if its collected? Might have a punt on one, i know they are not the best, but its only for light duty use
I bought a professional syphon gun with a tungsten carbide nozzle to replace my Machine Mart one, it was about £50 from Anglo Scott Abrasives of Wigan. Worth every penny extra.
http://www.angloscotabrasives.co.uk/
Looks exactly the same as the mm one. Is it the silver one you went for?
