Careful when you test drive it, it may be a bit tight leading to lots of side ways action!I know, but I'm now sick of this job and just want it done, so pushed on.
The ends of the axles are held into the diff with these clips. On went on ok and the other pinged off into the depths of the diff, thankfully I was able to fish it out with a magnet. Otherwise doesn't bear thinking about.
Back cover on with sealant.
Just need to bolt the prop shaft on then bolt the diff back onto the subframe from above! Ludicrous design bolting from above when there is no access to get to the fixings.
I'd snap it off now!Don't let the other side drop in when you refill it.
Snapped it off immediately after the first one disappeared.I'd snap it off now!
Must admit when I saw the photo of that pump I thought what a stupid design. How’s the diff?Snapped it off immediately after the first one disappeared.
Go on then what would you have done if it hadn't come out? Strip it or drive it?I almost jumped with joy! I'll be playing the lottery tonight, it came out with a drain.
