Screwdriver
Let's hope you don't get horse rabies (be difficult to tell if you did).
Maybe, but that years ago![]()
Ended up going to look at another mower just to fix odd bits for a friend (I'm now the designated local mower guy) and ended up finding a leak so to make life easier pulled the transmission and found the fill cap had a hole so new one ordered.
View attachment 534504View attachment 534505
The oil was only leaking from the hole in the plug to the pressure head from the expansion tank, once it got to the same level but in the tube connecting it stopped leaking so thankfully not been run dry etcThat looks like a hydrostatic transmission. They are quite fragile and prone to failure. It is the reason most of them get scrapped because a new transmission is quite expensive.
If it has been leaking it is probably been run when low on oil. If it does work again it's likely that its days are numbered.
Flicking down through the photos then suddenly came to the final one. Heard myself say “Wow”. What a great job !View attachment 534643
Re varnished after the repair.
The delamination of the ply wood was repaired by glueing the loos parts down and in one case patching it.
All age related dents, ding and scatches were left.
Waxing the parts.
Nice job. What's the copper coil for?View attachment 534643
Waxing the parts.
To link two bottles together.Nice job. What's the copper coil for?
Ah ha - So that's what that "bike" spanner in my dad's tools was, that never fitted any bike I had as a kid!
Spent ages fixing the string of LED's that go around the porch. It took less than a day for a squirrel to chew through the wires. I hope the little sod got his teeth burnt.By next christmas some of the bulbs will have failed![]()
it worksall done. nearly. got to connect the main power feed and charge it. but thats done enough for now.
fitted my new dashcam too.
