Carl Wilson
- Moray
Hello everyone. I was hoping there might be someone here with knowledge of these Siemens Sinamics V20 VFDs. I am currently trying to program one to run the motor on my milling machine.
I'm having a very frustrating time with this unit. I've attempted to program it by following the instructions in the manual, to the letter, for both "Quick Commissioning" and "Quick Commissioning through the Parameter Menu". Nothing I try works.
The vfd sits there, switched on and showing 0Hz on the display menu but none of my parameter changes appear to have any effect whatsoever. Out of the box, the unit ran the motor using the front panel (Basic Operator Panel) on the vfd. However, I cannot make any headway with getting external inputs working.
I've also tried various other programming and parameter set ups I got from trawling the Siemens forum. Again, nothing. No motor operation, I don't even get any indications on the LCD display when I operate the external switches or the speed pot.
There must be something simple I'm not doing either before, during or after setting the parameters. I cannot for the life of me see what it is.
I have been at it for a week, on and off, with no progress at all. I'm starting to think that it's just too complex for my needs.
I'm at the stage where if I cannot get it working in the next wee while, I will buy another, simpler to set up unit. I have a Teco on my lathe which works perfectly and has lots of features. It was easy enough to set up.
I bought the Siemens because I wanted quality. However if it's so complex to set up that I cannot fathom how to use it, then it's been a waste of money.
Has anyone got any ideas?!
I'd be willing to have a look at it (Not that I have any particular knowledge of that type of inverter, but I think I have access to the software which might help) but it depends whether you wanted the faff of sending it or if you just want to offload it.
