If the warning lamp isn't working, the alternator is then reliant on residual magnetism to self-excite, which will only happen at higher revs, and if it's been sat for a while, might not even self-excite.There's something a little funky happening with the alternator, seems to take a good few minutes or more (at least today) for it to kick in and bump the voltage up to 14V but once it kicked in it stayed there. Something to monitor and investigate. Battery hasn't been on charge at all since it's been on the road so it's obviously charging, I'd just expect it to start more or less straight away. The charge light also doesn't light up with the ignition on but I've been known to dislodge that before.
Old school regulators, the warning lamp essentially earthed through the rotor and provided the current for excitation which is why they were always a 2.2W bulb, however newer regulators (which are often fitted to recon units), the warning lamp simply activates the regulator, then the regulator pulls the excitation current directly from the battery terminal, however it still needs the warning lamp feed to get things charging or for the alternator to self-excite, which again, might not happen.
It usually takes high revs for a few seconds for an alternator to self-excite, so with a non-working lamp, depending on driving style and alternator gearing, it might simply not have been spun fast enough to start charging.
