- Birmingham
Well they do tell us they can multi-taskI think I can beat that.
Missus could sort the washing and load the dishwasher while having a xxxx
Much betterHad to re-visit this today as I couldn't get the crappie y piece to seal.
That's an understatementWell they do tell us they can multi-task![]()
At least the aluminium will corrode rather than rusting to the steel and getting stuck like the originals plus easier to remove the aluminium in the future if needed and I'm sure they will last quite a few years anywayThe aluminium bush will corrode onto the shaft even quicker than the steel one!
Except sit down and shut up.Well they do tell us they can multi-task![]()
He's right - it'll be rapid on bare steel and moisture around. The aluminium oxidising will make it like it's welded to the shaft - you will be cutting it off in lumps or machining it off.At least the aluminium will corrode rather than rusting to the steel and getting stuck like the originals plus easier to remove the aluminium in the future if needed and I'm sure they will last quite a few years anyway
Bought a Subaru Forester some years ago for the then OH - she complained the fan was crap, even on high. Finally found the filter, buried up under the dash - I reckon it had never been changed, despite the ticks in the main dealer full service history. She was dead impressed with the now hurricane force through the "new" filter . . .Car was due some servicing. Oil and filter to begin with..
I found where the long overdue cabin filter is hidden..
Had one ordered but amazon a bit slow, so for now vacuumed it out, the fan now performs much better!
They can do one normal task, badly, whilst whining about it. That is the limit of female multi tasking.Well they do tell us they can multi-task![]()
Oh well that's a 10yrs time future me problem, at least I can just melt the ali offHe's right - it'll be rapid on bare steel and moisture around. The aluminium oxidising will make it like it's welded to the shaft - you will be cutting it off in lumps or machining it off.
