dobbslc
- Hertfordshire UK
We've just passed there on the way back from Midsummer Norton acquiring a new Mini for the boy.Fleet Services,
Pretty sure that program was filmed around Hurley just along the Thames from Henley , I recognise several of the buildings from when we have stayed thereAnyone get murdered?
I'll ask before someone else - link please.
What's wrong with the classic crowbar wedged in the ring gear and an impact
Remove the spark plug & fill the cylinder with a starter cord or other thin cord till it is as full as you can get it . You'll be able to tighten the flywheel as well as undo it once the piston is up tight on the stuffed in cord .I could have done with that earlier in the week , torquing up the flywheel on the husqvarna . I had to grind and drill a little plate and bolt to the engine casing
Didn't see any murders but there weren't many people aroundAnyone get murdered?
But that was north bound.We've just passed there on the way back from Midsummer Norton acquiring a new Mini for the boy.
We came down the M4 on the way there, M3 on the way home.
And I was going to invite you in for a TYA coffee.Wave? You could call it that![]()
I have both cast iron and alloy 24" ones
It's not a husqvarna chainsaw it's a 150cc TE enduro bikeRemove the spark plug & fill the cylinder with a starter cord or other thin cord till it is as full as you can get it . You'll be able to tighten the flywheel as well as undo it once the piston is up tight on the stuffed in cord .
