When I used to work on industrial dryers as a field service guy they were a godsend, I could carry mine around in my tool box rather than having to scrounge Stillsons off customersThose chain wrenches are damn handy. Some people really struggle to wrap them the right way though which can be quite entertaining to watch.
If you're reading this and you've ever used one - you're probably smiling right now![]()
Yep!Those chain wrenches are damn handy. Some people really struggle to wrap them the right way though which can be quite entertaining to watch.
Though a more modern version.That's why I got it only £7Those chain wrenches are damn handy. Some people really struggle to wrap them the right way though which can be quite entertaining to watch.
Cant wait to get out the way of life
The multimeter has all functions such as capacitor, diode checks etc. It is class 3 rated so safe for mains voltage. The lead unputs also light up for a couple seconds when put into any mode so you know you are always using the correct terminals. Wireless voltage detection facility. Big easy to read screen with a backlight that can be turned on and off. Accurate. Pop up stand too for seeing the display lying under a car etc.
Nah that a length of 20mm bar and welderIs that for really tight oil filters?
Interesting I didn't know there was such a thing. Definitely one to acquireThe 'Manual on Machining Tufnol'.
They don't come up for sale often , so that's a good'un.......
Not Sean one of them in a log time.
Looks like you're going in to DIY hip replacementsA cheap dapping block set, for forming domes/hemispheres in thin sheet. It did a surprisingly good job on 1.5mm brass but that's really pushing it.
The punches are great; good sizes, good hardness and nice surface finish. The block is rubbish, there's duplicate hole sizes, huge steps between some sizes and the finish is rather poor on the smaller ones. I may buy a decent block if I find it need one but it's mainly the punches I'm after anyway, so I'm pretty pleased for 30 quid.
It put its head up, and I fired.....Interesting I didn't know there was such a thing. Definitely one to acquire
I could have done with that earlier in the week , torquing up the flywheel on the husqvarna . I had to grind and drill a little plate and bolt to the engine casing
