Negative - the car body is but a shellis it in the car under a seat etc door jam bottom
Thanks for looking - looks like I'm heading to buy a tap - to use just once on a half nut.Looked at work today , no luck I’m afraid
Bolt World
boltworld.co.uk
you sure its 1.75? my usual goto above for oddball thread size shows 1.5 and 2.0 in the range of fine threads...
whats the size across the flats of the original nut?
i was more wondering if i had any brass large enough to make one, but i fear i may not as it is likely 32mm AF, so larger across the points and my largest stock is currently 30mm...only stuff i have larger than 30mm is a 60mm bit of en8 thats waiting to be turned into a collet chuckYea, if you can find that and measure across the flats then we can help you find a replacement for it![]()
I don't know how to individually quote comments from various people on one post - so this is a reply to "qwakers" - "BrokenBiker" - "hotponyshoes" and "droopshoot.Are these different to the nut you're trying to replace?
SJ606 NUT for DOOR HINGES (8 per car)
www.sjsportscars.com
It's hard to tell from their photo, perhaps not big enough. Though I presume you've tried the various Lotus specialists before posting.
To multi-quote, click the "+ Quote" button below each post, then in the reply box, click "Insert quotes". You can then put text between them.I don't know how to individually quote comments from various people on one post - so this is a reply to "qwakers" - "BrokenBiker" - "hotponyshoes" and "droopshoot.
Thanks for this - I'll give it a go next time.To multi-quote, click the "+ Quote" button below each post, then in the reply box, click "Insert quotes". You can then put text between them.
I figured you'd have checked the obvious places first.
I have just ordered a second set of 1 1/2" cup brake cylinder rubbers for the 1944 Austin, the first set are resting somewhere! had the same issue with core plugs for the engine, second set arrived the day before the first set decided to stop hiding................................Do you have turn-ups in your workshop trousers / overalls?
Joking aside, I sympathise. I'm still looking for a bag of dash gauges I was given for a project car that I've since moved on and has now been scrapped. Not a small bag, by any means, but it's disappeared. Oh, and the bag of interior trim offcuts I was given many years ago, and the pile of A3 sheets of clean cardboard I bought for making templates. All pretty big items, all vanished without a trace.
Thankyou so much for the offer "doubleboost" - I've ordered the tap now - if this fails I'll come back to you.If you send me the part screws on to I will make you a nut
Thankyou for going to the trouble of photographing and posting this pictures - much appreciated.Any good?
Afraid the battery in the caliper dead and I don't have a spare.
Pic's are the best I can do.
Edit
New pic of the stud the nut has come off
