Pigeon_Droppings2
- london
One think that really helped me is having a dedicated box for things...so I know for sure if I need some tape and it isn't in the tape box then I need to go buy some!
Don't you need it for gardening?![]()
In place of cable ties for your pea framesTell me more?
I keep all mine for rebar.Being ruthless tonight! I know I'll regret binning this SWA armour though!
I've had to start another scrap bin:
This is what i have been doing this week. I have been sorting the boxes i have already semi sorted but giving what escapes the cull a final resting place.One think that really helped me is having a dedicated box for things...so I know for sure if I need some tape and it isn't in the tape box then I need to go buy some!
an hour on it tonight)One think that really helped me is having a dedicated box for things...so I know for sure if I need some tape and it isn't in the tape box then I need to go buy some!
Keep it to hold the millstone around your neck, bin it to set yourself free!I've only ever really used it for mousing shackles.
Baling wire to tie beanpole frames, help trail climbing plants.Tell me more?
with carrier bags full of dog sht
You have two solutionsIn the space I have, I'm struggling to move. I've erected new s/hand shelving but can't really get to it as a Capri on dollies is quite tight to it.
All I can think is move this Capri sideways which will close the walkway between the other Capri and make that walkway between the two cars tight / unusable.
It's already tight what with two spares or repairs mobility scooters, a moped, an industrial woodwork vac etc.
Then fill the inaccessible shelves with stuff I don't need to get to regularly and then move the Capri back. At that point I MAY be able to get the shell Capri next to the shelves up on a rotisserie which will at least give a feeling of space (until I put it level). However...at that point I should be perhaps able to work on the other, fairly intact Capri and get that running reliably enough to be backed in and out.
Seems to be there is only one thing causing a problem.You have two solutions
Aggressively reducejunkman treasure.
Build an extra new double garage
"Capri" seems to crop up repeatedly.Build an extra new double garage
Living in a national park I understand the planning situation. But with out controlling you nemesis of man treasure hording your new converted stable workshop will just end up full as well, and in 18 months there will be a new thread “How do I empty junk out of my garage and stable”In the green belt AONB where I am that's a non starter if I was to go for planning permission.
The best option would be convert / rebuild the old stable block I have at the back of the property as a workshop.
I did that.. And filled that one as well. Its quite strange as on Friday i had a real goodday and reduced about 20 boxes to 5 and the rest of the stuff was binned or put in forever homes with labels. But yesterday was no where near as productive some of it was logistics but a lot of it was my mind was not in such a ruthless mood and things i thought could go the day before i thought about keeping the next day. Very weird.You have two solutions
