And the battery ones…
The fakita 18v have speed control.
Never understood why the Makita version doesn’t?
Me neither, given the use they’re put variable speed to me is essential. I only got mine as it was in a job lot of Makita stuff a mate was selling.The fakita 18v have speed control.
Mate has 1 he uses for wood carving. I have used it on wood and it was pretty vicious, can't imagine what it would be like on meal.
Playing cards by yourself ..... with a good hand ??No, more details please?
It's the handle for a window cleaners squeegee . the bottom clamp under the picture and two screws plus the rubber blade is missing My squeegee circa 1988 is like your picture but in high grade stainless steel.View attachment 526161
To reply to the question:
"What is that brass thing?"
Paint Stripper attachment for a paraffin blow torch.
Hope this helps @..........
1971 I saw her live for 3/4 hr , in very very hot pants in a Combined Services Entertainment show in our 50 seat cinema Wulfen BFPO 15 .. I think it was Marty's way of giving her an introduction into show business . I suspect millions of possible babies were terminated that night after lights out .Ooof in 2026? REALLY?
We had this happen quite a lot both in Summer & in winter .. in Summer one side was in th sun for 5 hours so an imbalance was registered . I cold weather we discovered the shaded side adjacent to the still frosted caravan was 4 degree lower then the side in in the sun . So too hot or too cold on one side or 4 or so minus centigrade can upset the auto tyre reading which send out ultra sonic pulses and does comparison whit all four wheels especially if the microchips get below - 10 oC . Full programming up dates at servicing's and when we reported the problem seem to have cured most problems , but Friday after about -7 oC overnight the warning lights came on again on the side next to the caravan where the chill factor would be the greatest . It reset itself within 75m of me leaving home , 50 mtrs of it sounding the alarm before I could pull in safely .An Enterprise rent a van.
Company car has gone wonky.
It is saying.
Forward assist fault.
All 4 4 tires are deflated.
AA arrived. found no issues with tyres, but could not ret the fault lights. This limits the car to 2omph.
So it went away and a van arrived.
I too found that problem I have a 10 cu ft tank on my compressor .. IMO it needs to be at least 15 cu foot unless you are removing wood / doing wood carving with them .its why all my die grinders are air, strong enough to chew metal but stalls easy if snagged...those Makita 240V are sent here by the enemy to kill us![]()
Main ECU failed.We had this happen quite a lot both in Summer & in winter .. in Summer one side was in th sun for 5 hours so an imbalance was registered . I cold weather we discovered the shaded side adjacent to the still frosted caravan was 4 degree lower then the side in in the sun . So too hot or too cold on one side or 4 or so minus centigrade can upset the auto tyre reading which send out ultra sonic pulses and does comparison whit all four wheels especially if the microchips get below - 10 oC . Full programming up dates at servicing's and when we reported the problem seem to have cured most problems , but Friday after about -7 oC overnight the warning lights came on again on the side next to the caravan where the chill factor would be the greatest . It reset itself within 75m of me leaving home , 50 mtrs of it sounding the alarm before I could pull in safely .
Re:-
Setting is usually done on a programme in the gear cog icon , go down the tool tasks till you get tyre pressure and click it has been done and needs resetting .
NO IT IS NOT.It's the handle for a window cleaners squeegee . the bottom clamp under the picture and two screws plus the rubber blade is missing My squeegee circa 1988 is like your picture but in high grade stainless steel.
You tell ‘emNO IT IS NOT.
AS i said it tells you on the item.
Be like half of my stuff Graham, its been put somewhere safe so its easily foundWell @roofman I am not sure about that, we have a civil defence force on our side. It's the tool pixies. They stole my die grinder because I cannot find it![]()
Back then, sure, but time is never kind1971 I saw her live for 3/4 hr , in very very hot pants in a Combined Services Entertainment show in our 50 seat cinema Wulfen BFPO 15 .. I think it was Marty's way of giving her an introduction into show business . I suspect millions of possible babies were terminated that night after lights out .
Arrived yesterday but was having way too much character building fun fixing the oven. More Milwaukee stuff in M12 flavour since PowerToolMate had 10% off and already good prices.
Installation driver with swappable heads should save me trying to contort myself in different positions and I don't bend well now
Buying filament in bulk is approx £6/Kg, or £10 individually. Difficult to tell the size from the photo but I think they would take a good few hours each to print so the price seems reasonable.Out of interest to those that have 3D printers, what would the cost (I paid £36 off eBay) to make such a thing with it's 2 main shells and 2 lift out organisers?
