90% of these logs are 4-6" so I've been able to process them significantly quicker than the chainsaw here.I'd say the 372 would be quicker. Anyway theres no point being quick if you can only cut tiny logs, 5 or 6" max depth on that?
Steel toe caps will stop a chainsaw, but not so much a carbide tipped cut off saw... I dont think it would notice they were there.
Yea they definitely won't stop the blade but like motorbike PPE vs jeans in a slide it gives you more time to react so potentially just a bad cut rather than your foot becoming a mermaids tail.
Anyway I printed out some more washers so it holds the metal one on the arbor meaning it can't vibrate out and allow the disc to unbalance.
Couple of hours later and pretty much full!
). The panel is only 0.7mm thick (over the paint!) which doesn't leave much meat for grinding things flat, so I thought I'd see if I could butt-weld it with the TIG and planish it flat after...
