It doesn't matter, someone will know better!!What the hell does HE know?![]()
If the engine speeds up when you use the piston lifting pin, the mixture is too rich. If it slows down, it is too weak. When the mixture is correct, lifting the piston should cause the engine speed to temporarily slightly increase, then return to normal.One simple test - lift the piston with the lifting pin underneath. When you let go the piston should fall freely down with a satisfying clunky - if it doesn't inspect the piston and bore......
Summary: SU carbs are super simple but unreliable and often wrong when they left the production line"
Simple is exactly what I need - the guide is ideal with simple info in layman's terms.Very simple guide which might help.Phil
not just that but actually attacks metals too over timeThe increased ethanol content of modern fuels has killed many many otherwise good bits of kit that had the earlier rubber / neoprene parts . My 23 yr old chainsaw being a prime example :- rubber on the carb needle valve tip , priming bulb , fuel lift tube and return pipes all disintegrated . In the carb I noticed a very fine sediment not sure if that was partly caused by ethanol or not .
Drinking petrol? I would start at the basics, check compressions, valve clearances (too tight will cause high fuel consumption/running problems, ) points settings/dwell angle , ignition timing , mechanical and vacuum advance , plugs , air filter , induction air leaks etc before attempting to adjust the carb. A cheap vacuum gauge is a very underrated tuning toolThe car made a 159 mile trip yesterday so the rebuilt carb works.
It’s drinking petrol and runs “ok” with rare burst of performance so something still needs work but it’s progress![]()
