It doesn't matter, someone will know better!!What the hell does HE know?![]()
If the engine speeds up when you use the piston lifting pin, the mixture is too rich. If it slows down, it is too weak. When the mixture is correct, lifting the piston should cause the engine speed to temporarily slightly increase, then return to normal.One simple test - lift the piston with the lifting pin underneath. When you let go the piston should fall freely down with a satisfying clunky - if it doesn't inspect the piston and bore......
Summary: SU carbs are super simple but unreliable and often wrong when they left the production line"
Simple is exactly what I need - the guide is ideal with simple info in layman's terms.Very simple guide which might help.Phil
