Nomad
- North Devon (for how long?)
For background, I'm a lot more familiar with carbs on classic Fords so Strombergs & SUs are a new thing for me.
My Marina cut out yesterday, the small bore flexible fuel line from the float chamber to to main jet is kinked and not allowing fuel to flow. This is a bad thing and hopefully the only fault.
The car came from a "make do and mend" chap so the carb may be from something totally different but its been running ok since I got the car (engine never felt crisp but was always smooth and reliable despite low power - it's a B series in an estate car so isn't a surprise).
My thoughts are to order a new pipe (comes with main jet), also a new standard needle in case what's now fitted isn't correct.
Everything else seems ok (float needle, no wear on the throttle spindle etc)so I'm happy to keep using the carb as it is.
Any advice or words of wisdom? I'm looking for reliability not race car performance.
Example of what I think I need
Guide to dismantling them
sucarb.co.uk
Carb setup guide (wish I'd seen this years ago)
sucarb.co.uk
Education crash course needed. Tell me what I don't know
HS2, HS4 & HS6 Carburetter Dismantling – Step-by-Step Guide | SU Carburetters
Comprehensive dismantling guide for HS2, HS4, and HS6 carburetters, covering suction chamber removal, jet assembly disassembly, float chamber access, and throttle spindle removal.
HS Carburetter Tuning – Single Carb Adjustment Guide | SU Carburetters
Step-by-step guide to tuning HS single carburetters, including idle speed, mixture adjustment, emission control checks, and fast-idle settings for optimal performance.
