detail-library.co.uk
That’s the ones, go through the timber & into the wall in one go, it was a good while ago, but from what I remember you tap them in with a hammer & screw the last bit. Did a really good job.
I thought they'd be fine - they are frame fixings after all - but it appears there is some concern about how well (or reliably) they could hold when screwing into a brick wall. So the suggestion was to use these insteadThat’s the ones, go through the timber & into the wall in one go, it was a good while ago, but from what I remember you tap them in with a hammer & screw the last bit. Did a really good job.
Good point - I'll use a new drill bit. I had a quick look for ones with four edges (not heard of them before) and it seems like they only come in longer sizes. I'll use a new regular one instead.The self tapping concrete screws are quite sensitive to drill diameter, so if the bricks are at all hard, use a new, good quality bit (I like the ones with a cross, four edges at the end) and try to bring the dust out as you are drilling.
you will walk in with water your coats will drip with water rain angles will get into the area as it always does if you think it wont affect the wood it will do more so at the door way entranceThinking about Gaz's suggestion earlier (plastic lumber) maybe I should consider running another course of bricks on the inside for the frame to sit on? I was hoping to fit the frame directly to the concrete slab for simplicity and keeping the wall insulated with no cold bridging at the bottom of the wall. As previously mentioned, I won't be able to bring the floor level up much at all.
EarplugsNone of my hammer drill bits will go through timber (well, not easily). What do people use nowadays?
Use twist drills, or blacksmith's drills, for smaller holes, wood drill bits for medium sized holes, and hole saws for large holes.None of my hammer drill bits will go through timber (well, not easily). What do people use nowadays?
Nothing quite like having a range of opposing opinions.Fischer frame fixings as said. You don't want concrete screws for timber
