angellonewolf
- bristol england
do easy stuff first oil water in the drain then do the hard stuff after cheak the current by putting your clamp meter over the brown wire only on its own (assuming its a single phase)
im sure i seen on here before run it up untill it stops cheak the temp of the motor then remove the belt have to do this quite quick and see if you can try try to turn both belt wheels see if its stiff to turn (see if the bearings are stiffing up)
and post a pic of the plate on the compresser so people on here can give more informed ideas
there are better people on here than me but do the easy stuff and get that out the way first you dont want to go buying this and that swaping stuff and find in the end it was somthing simple
