I think that it works ok on the X1C but need to double check when I find my flat plates out.ABS / ABS Pro, I meant ABS in the general sense. We've never bothered with it since our original dismal failures on the Anycubic i3 Mega S.
uk.anycubic.com
How much?After another look through Bambu site I found the list of authorised resellers, and found that Additive-X have the P2S combo in stock.
Phoned to confirm, and they were quite helpful. 10 more in stock and mine should arrive tomorrow via DPD.
I have to ..lolResist.![]()
You print the holders for loose desiccant and fit them where you have placed the packets. Models on makerworld or thingiverse etc.The most well packaged item I've ever recieved. A lot of thought appears to have gone into it
Hour or so to unpack and set it up. Temporarily in the lounge on the carpet.
Unsure where the AMS desicant is supposed to be so at the front is out of the way.
First print in PETG
Top of the doorway arch and the two holes at the front are not perfect but I am impressed!
Second print a mini carabiner
Currently letting the AMS do some drying. Seems it cant heat etc while printing so thats a task to be done before hand.
Somewhat irritating is it does not spin the spools constantly, or even frequently. It rotates about 10 degrees at about 5 minute interval, which on a short drying session, is not going to be very even.
Where is best to buy Bambu spares? Their shop doesnt appear to list everything.
Is it worth gettjng a high flow nozzle, or different sizes? 0.4mm seems very slow for unimportant parts. I'm told 0.8mm is very coarse
Textured plate works but I likely want a smooth or patterned one.
If you think the bambu is slow, you've obviously not used an Ender type printer!Where is best to buy Bambu spares? Their shop doesnt appear to list everything.
